Autoplay interval longer than 5 seconds
We use the Google Review widget to display real-time reviews in our office. The widget is set on a tab of the Chrome browser which auto-refreshes at a set interval so that we don’t get too far into history. The intent is to show the team our last few dozen reviews.
The 5 second autoplay interval is too short. Some of the reviews are lengthy, and it is not possible to read the whole review before the screen moves.
Greetings @MRR :wave:
You can manually set the needed value in the Interval field:
Please check it and let me know if it helped :wink:
Thank you! It makes sense that this functionality was already part of the platform. The UI just didn’t make it obvious to me that the field was customizable and the dropdown represented a few common choices. I should have clicked around a bit more. The system is working great now.
Yeah. I agree that this feature isn’t quite obvious, however, I am happy that you are good now!
If anything else comes up, we are here to help :wink:
This does not work for me. When I type in a number the UI converts it into thousanths of a second. I have tried several browsers.
Hey there @user13541 :wave:
Thanks a lot for bringing this to our attention!
I’ve forwarded this to our devs. I’ll report back once the issue is fixed :slightly_smiling_face:
Hi @user13541 :wave:
The issue is fixed! Please check it out and let me know if it’s fine on your end :wink:
