We’re super excited to introduce a new playback progress style in the Audio Player app — the Waveform visualizer! ![]()
Instead of a plain progress bar, you get a waveform that shows how the audio intensity changes over time — so listeners can quickly spot louder moments and scrub more naturally to the part they want.
You can enable this option in the Player section under the Settings tab:
Once it’s turned on, the widget will automatically analyze your tracks, generate the waveform, and save it in the widget settings.
Tracks from the outer source added via links (YouTube, SoundCloud, etc.) aren’t analyzed — a random waveform will be automatically generated for them.
Guys, have you tested the new option? Let us know what you think in the comments — we’re all ears
