AI-Generated Summary
AI-Generated Summary is in English, even though I changed the language to non-English. Complete the AI prompt by adding a command for the summary to be in the user’s chosen language.
Hi there @user23 :wave:
The thing is that the language settings are applied to the widget elements such as title, date, etc, but not to the AI Summary.
The language of the AI Summary depends on the review language. I see that all your reviews are in Polish and the AI Summary should be in Polish as well.
I’ve shared your request with the devs and will get back to you once I receive a response from them :slightly_smiling_face:
The issue is fixed. Please check it and let me know how the AI Summary works :slightly_smiling_face:
Thanks, it is ok, now
Great! You are most welcome :wink:
