AI Chat box
Good morning, I need a AI chat box for my blog of genealogy, on Blogger. Can you help ne please ?
Thank you !
Jeff
Hey @Jean-Francois_Dagena,
Can you not use Elfsight’s AI Chatbot widget? Once installed, you can restrict it to display only on your blog page.
Cheers!
Je ne connais rien en technique. Pouvez-vous m’aider ?
Follow the instructions provided here: AI Chatbot Widget — Add AI Chatbot Assistant to Your Website! [FREE]
If you need additional help, contact Elfsight Support here: https://help.elfsight.com/
Best wishes.
Hello @Jean-Francois_Dagena and welcome to the Community :waving_hand:
As Petar correctly mentioned, we’ve got an AI Chatbot widget that should be just the thing for you.
Here are some articles that will help you set up your AI Chatbot:
Here is our tutorial explaining how to install the widget to the Blogger platform: Adding Elfsight Widget to Blogger Website - Elfsight Help Center
If you’re facing difficulties with the installation, our Support Team will gladly assist you with it. Just request the installation and our agents will reach out to you :slightly_smiling_face:
