Adjust size of Footer text & Move position of Badge (Above or Below Item)
Need to be able to edit all text. Including color of descriptions, footer text size, and where the badge is located.
Hi there, @Alex_Kwon and welcome to the Community :waving_hand:
Thanks for sharing your thoughts with us!
Under the description you mean Menu and Item captions, right? Also, could you please clarify what you mean under the footer here? I’ll be happy to check if there is a custom solution :slightly_smiling_face:
Yes so the badge right now only goes under/left of the menu item. Would like an option to go on top the menu item.
For the footer text, it’s the text that appears in the footer of each section. I don’t see a way to edit the size and it’s too small for mobile.
I guess you’re referring to the Menu Caption:
If so, you can change its size right in the settings:
To change its color, please the code below in the Custom CSS field on the Style tab of your widget’s settings:
  [class*="Info__InfoCaption-sc"] {
      color: red!important;
Regarding the badge position, I’ll check with devs if we have a custom solution for this :slightly_smiling_face:
Could you confirm two points: (1) whether all menu items will display badges or only certain ones, and (2) whether badges should be uniform across items or vary by item?
