Add more customization options for header elements and Follow button
It would be great to have more options for customizing header elements and counters, including the ability to hide them when needed. Also, having more control over the Follow button placement would make the widget more flexible.
Hi there, @user2062 :waving_hand:
Good ideas, thanks for sharing! If more users support this request, we’ll try to consider it in the future :slightly_smiling_face:
As for now you can hide each header element individually using the CSS codes below:
Author block
.es-header-account-author-container {
  display:none!important;
Counters
.es-header-account-counters-item {
Follow button
.es-header-button {
Regarding the button position, could you please share how you’d like to display it? We’ll be happy to come up with a custom solution for you!
Thanks Max:
Meanwhile, are you guys working on making the popup text not one big blob of a paragraph? That’s not the way it’s displayed on Instagram.
I’d also like to enlarge the text inside the popup; it’s very small.
Thanks much, Katie
Sure, our devs are working on this issue and my colleague Serj will keep you updated in a support ticket :slightly_smiling_face:
Thanks!
