Currently, the corner radius setting only affects the background container. It would be great to have the same option available for different layouts as well, since I’m using the widget without a background.
Hi there, @user2062 ![]()
Thanks for sharing your idea with us! I totally get your point and agree that it would be awesome to have a special setting for layouts without a background. We’ll try to think about this improvement in the future ![]()
Folks, if you’d also like to change the layout border radius and you’re not using a background, here are the solutions:
Grid layout:
.es-grid-layout {
border-radius: 0px !important;
Thumbnail and Showcase Carousel
.es-carousel-inner {
These codes should be added to the Custom CSS field on the Settings tab of your widget’s settings
Thank you! And of course, I had to make it 0px, not 20px.
Cheers, Katie
