The LinkedIn feed keeps its off-screen posts in the accessibility tree, so the screen reader reads posts that are not visually displayed and cycles through the entire feed. The user cannot easily move past the section.
Why it matters:
The screen reader reads content that is not on screen, so what is heard does not match what is shown.
The user gets stuck cycling through every post and cannot skip the section to reach the rest of the page.
How to fix it:
Hide off-screen posts from assistive tech (aria-hidden=“true” on non-visible slides) and remove them from the tab order, so only visible posts are read.
Provide a way to skip the feed, or limit how many posts are exposed at once.
Since this is an Elfsight widget, this likely means adjusting its configuration, requesting a fix from the widget, or replacing it with a more accessible feed.
WCAG criteria it fails:
1.3.1 Info and Relationships (A, 2.0), because content that is not visually present is exposed to assistive tech.
2.4.3 Focus Order (A, 2.0) if the off-screen posts are also keyboard-focusable, which you can check in the focus pass.
