Got a question about Elfsight widgets or feel like you need a hand? This category is just for you to share your issue, get advice from your peers and help others.
If you need help, create a new topic, name the widget and ask your question. If you know how to help others, please do — the community will highly appreciate it
With the way our service works, each app has a separate subscription. In this way, if you pay for one app (for instance, Instagram Feed), the logo gets removed for all the Instagram Feed widgets you create. But if you need to use another app (let’s say, Facebook Feed), you need to subscribe for Facebook Feed app separately to have the logo removed.
If my explanation didn’t help or your case is different, please contact our Support Team, they will be very happy to look into the issue and provide assistance
hola
ayer cree el widget de whatsapp y lo instale en la pagina de squarespace sin problema pero hoy no me aparece, volví a hacer el preceso y aun no me muestra el widget en la página web.
hello
yesterday I created the whatsapp widget and installed it on the squarespace page without problem but today it does not appear, I did the process again and it still does not show me the widget on the web page
