Ability to sort categories alphabetically
I recent created a portfolio of some of our website designs but wanted to categorize them so clients could look at the specialty that was most relevant to them. The list was long and because it was not alphabetized, it took quite a while to assign categories to each project. Also, if you select an item and go back to add more or change it, the system brings you to the one you last chose, which might be at the bottom of the list and no way to scroll up :(.
Would also be great if you could add categories on the fly without having to navigate down to categories and add them and then go back in to the project.
Hi @Lisa_Dye, many thanks for your suggestion and all the details provided!
I must say that a popup with categories doesn’t work correctly now, my apologies for this inconvenience. Our devs are already working on it, and I’ll let you know once everything’s sorted :slight_smile:
As for the alphabetical sort, we’ll try to think about it in our future releases :slight_smile:
Thanks a lot for your help, and welcome to the community!
Hi @Lisa_Dye, we’ve fixed the issue with the long list of categories, so everything should be fine now :slight_smile:
This is great, thank you! :slight_smile:
We would love for categories to be alphabetized to make it easier for our prospective clients to find the category they are searcing for. If you look at our existing set-up, https://www.infinitymedicalmarketing.com/services/website-design-for-medical-doctors#WEBSITEDESIGNPORTFOLIO, you’ll see why we need it.
Hi there, @Lisa_Dye :waving_hand:
Thanks for sharing your thoughts!
You’ve previously requested this feature, and I’ve merged your comment with your initial request. If this idea gets more votes, we’ll try to consider it in the future.
As for now, you can manually sort categories in alphabetical order using the drag-and-drop option :slightly_smiling_face:|
