Ability to change the posts order
Reorder posts in preference rather then have them in date order
Hi there, @user21923 :waving_hand:
Nice idea, thanks for sharing! We’ll try to think about adding an option to change the posts order manually :slightly_smiling_face:
If you don’t like the date order sorting, you can also consider using a random sorting option:
Hey Mac yes that would be great only feature I feel is missing is being able to display the order of your post in whatever way you want !
Hi @T_slickz_Detailing :waving_hand:
Thanks a bunch for the feedback! We’ll keep this idea in mind and see for more interest from the community :slightly_smiling_face:
