4 Weekly Menus on a Rotating Basis
One of my clients wants a pop-up menu to appear when the website is loaded. There are 4 weekly menus that should repeat once a month. The menu is scheduled to change every Monday. The rotation remains the same (Menu 1 in Week 1 of the month, Menu 2 in Week 2, Menu 3 in Week 3, Menu 4 in Week 4, Menu 1 in Week 5, Menu 2 in Week 6, Menu 3 in Week 7, Menu 4 in Week 8…). Is it possible to implement this using the pop-up module? Do you know what I mean?
Best regards,
Dominik
Hi there, @Dominik1 :waving_hand:
The only option for now is to set a separate schedule for each widget, that will occur on the same dates on the monthly basis. Here is how you can do this:
  1. Go to the Schedule section on the Settings and set the Start and End Dates for the popup display in the current month. For example, April 12 - April 18:
  1. Then open the Repeat section and select Custom. Set Frequency to Monthly, Every 1 month, on the same day each month:
This way, the popup will show up from 12th to 18th each month: April 12 - April 18, May 12 - May 18. June 12 - June 18, etc.
If you wanted to trigger the display on the 1st/2nd/3rd Monday of each month, unfortunately, there is no way to implement this now.
Let me know if this clarifies things or if you have any questions left :slightly_smiling_face:
